Page 7 of 11
Posted: Tue Dec 10, 2019 10:33 am
Picked up the donor truck and brought it to PointsNorth Automotive to pull the motor
The Rental
Posted: Tue Dec 10, 2019 10:35 am
had that big block out in record time
Posted: Tue Dec 10, 2019 5:42 pm
HillBilt wrote: ↑Tue Dec 10, 2019 8:05 am
My AFRs are mint on idle and cruise parameters. Actually way too rich on cold start choke mode. hard to tell on WOT as I’m not really watching the screen haha. Fuel pump issues were 3yrs ago, but who knows, maybe some damage occurred as it would of been lean.
Get a shitty cellphone to video the AFR on WOT. Poor man's datalogging.
Posted: Tue Dec 10, 2019 9:53 pm
Scott Cee AKA 2drx4 wrote:HillBilt wrote: ↑Tue Dec 10, 2019 8:05 am
That’s actually a really good idea. Could mount my phone to record it for a few WOT passes.
Posted: Tue Dec 10, 2019 10:31 pm
by Mr.gutsy
Ever pull the other plugs or heads off the old engine?
Posted: Wed Dec 11, 2019 5:02 am
Probably won’t happen till after the new motor is in
Last update I got was him and Logan were grabbing the rental from my shop in the am and dropping it in so should be tuning by the afternoon hopefully
Posted: Thu Dec 12, 2019 10:15 am
Mr.gutsy wrote: ↑Tue Dec 10, 2019 10:31 pm
Plugs got changed every fall for PM. I just put new plugs in it about 1hr before it let go. Plugs were always black and fouled which is why I routinely changed them. It was never suspected of having a lean condition. I dont think you would get a read from any of the other ones as they were brand new. Ill pull it apart in time, just at the absolute bottom of my list of to-dos atm.
I was thinking about my fuel, as it does alot of sitting, with fuel now days having a way shorter shelf life maybe degraded enough to the point it was detonating? It hasn't ran since July..
On another note. The Rental motor is in and running as of last night. Needs alot of tuning. Everyone is commenting on how mean the motor sounds, but its more poor tuning than anything. After I redo the initial tune and get some drive time on it, I feel it will calm down a bit. My motor did the exact same thing on first fire until the computer learned, and the rental is running off my old motor tune right now.
Posted: Thu Dec 12, 2019 11:44 am
by Mr.gutsy
Thats not suprising as its a whole new animal. And as far as the plugs go you may be able to see specs of aluminum on them if other cylinders were having issues. I still think you may have gotten a batch of fuel thats not what it was advertised as. The import guys see it all the time because their knock sensors dial back the timing.
Posted: Mon Dec 16, 2019 8:39 am
Posted: Mon Dec 16, 2019 12:00 pm
by Mr.gutsy
I cant recall were i have seen that before... oh wait I totally remember.
- 4124743.jpg (20.82 KiB) Viewed 4384 times
Posted: Mon Dec 16, 2019 3:11 pm
Posted: Mon Dec 16, 2019 7:23 pm
Posted: Fri Dec 20, 2019 1:41 pm
Posted: Fri Dec 20, 2019 1:45 pm
Attempted to build my own inserts from some UHMW. Kind of a fail, maybe with some steel clamps one could heat it up to help maintain the shape. But wasn’t going to invest a lot of time at this point. Got HMF to cut me some steel cage inserts instead.
Posted: Fri Dec 20, 2019 1:47 pm
Truck is in glass shop today getting a new windshield with no rubber centre seam. Got all the wiper linkage made up and working. Waiting on a motor to arrive. Went with a YJ wiper motor.
