![Headbang :headbang:](./images/smilies/Headbang.gif)
wouldn't register on the charger, so i hooked it up with jumper cables to another battery I had, let it sit like that for an hour or so to help bring up some charge/balance the two batteries without running a bunch of volts to it. This battery is only a couple months old, so odds of success are good.
After the voltage quit dropping fast, I hooked the charger up to the 'good' battery, mostly out of convenience. Doubling the capacity makes it seem like the dead battery isn't such a big deal
Now there is enough for the charger to see, it thinks the whole bank is running about 50% capacity and can do some work
and with everything charging at 14.36 volts. there are both lead acid batteries, so they can handle a fair bit of abuse. 14 volts isn't much at all, checked it periodically and neither was getting warm, cables never got warm. Let it run for a couple hours.
After a couple hours, unhooked the spare battery and put the charger alone with the 'dead' one. had enough volts at this point to be recognized, let it run for a few more hours.
Unhooked everything, after an hour it was still showing over 12 volts
![Smokin :smokin:](./images/smilies/smokin.gif)
truck ran like absolute shit at first, shut it off, started it again and it smoothed itself out.
small tech is still tech, so might as well post it. With an older battery that is very dead, it may need to be opened up and cleaned/refilled with acid before being able to hold a charge. this is free and easy, worth trying for very low batteries.
